Help identifying plug!
Old Sep 21, 2005 | 12:31 PM
BlKdOutEk's Avatar
Default Help identifying plug!
Where does this plug go? The engine harness is from a 96 ek, and the engine is a obd1 b18b1. This plug runs along the map sensor plug.
Old Sep 21, 2005 | 03:41 PM
BlKdOutEk's Avatar
Default Re: Help identifying plug! (BlKdOutEk)
ttt
Old Sep 21, 2005 | 04:04 PM
AudioFuct's Avatar
how many wires are going to it?
Old Sep 21, 2005 | 04:52 PM
4drmadness's Avatar
Is that the hook up for the TPS?? how many wires going to it could possibly hel out also...
Old Sep 21, 2005 | 06:44 PM
rainforest's Avatar
Default Re: (4drmadness)
idle air control valve or power steering pressure switch,
Old Sep 21, 2005 | 07:15 PM
RotiEatter's Avatar
Ditto
Default Re: (rainforest)
Intake Air Temperature plug. You need to switch it to the right plug that will work on your LS intake manifold.
Old Sep 21, 2005 | 11:05 PM
BlKdOutEk's Avatar
Default Re: (RotiEatter)
Well it's not the I.A.T plug b/c i already plugged that up...I will check the number and color of the wires tomorrow, but I'm almost positive that there are 2 wires on that plug.
Old Sep 21, 2005 | 11:06 PM
BlKdOutEk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rainforest &raquo;</TD></TR><TR><TD CLASS="quote">idle air control valve or power steering pressure switch,</TD></TR></TABLE>
My Dx didn't have power steering so i know it isn't that.
Old Sep 22, 2005 | 05:40 AM
RotiEatter's Avatar
Ditto
Default Re: (BlKdOutEk)
If you tell me the colors I can look it up for you.
Old Sep 22, 2005 | 05:48 AM
RotiEatter's Avatar
Ditto
its probably for the evap purge solenoid. there are only 2 plugs like that.
Old Sep 22, 2005 | 07:58 AM
BlKdOutEk's Avatar
there is a grn/blk and red/yell wire coming out of the plug
Old Sep 22, 2005 | 01:22 PM
dynamo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotiEatter &raquo;</TD></TR><TR><TD CLASS="quote">its probably for the evap purge solenoid. there are only 2 plugs like that.</TD></TR></TABLE>
That's what I think it is too. You will probably have to extend it to reach the top of the manifold (I had to extend mine on a 00 Si harness to reach the top of the B18C1 intake manifold). The red/yellow is the positive, and the green/black is the ground. See diagram below:
Old Sep 22, 2005 | 08:09 PM
BlKdOutEk's Avatar
Default Re: (dynamo)
Ok. Thank you everyone for your help!
Banjo the Ninja
Sep 4, 2008 10:38 PM
GsDAteg
Oct 7, 2007 12:58 PM
blinger
Apr 25, 2007 02:00 PM
2000CX
13
Oct 21, 2003 04:36 AM
