b16 obd question
Old Oct 9, 2005 | 07:26 PM
sqwale's Avatar
Default b16 obd question
i have a 97 civic im planing on getting a b16 iv been doing alot of searching and i see alot of companys sellin engines like hmotorsonline and jdmcustoms only have obd1 b16's. i have obd2 and am wionderin if the obd1 will work or if i can change to obd1 or vise versa. thanx
Old Oct 9, 2005 | 10:43 PM
JDM1civic's Avatar
Default Re: b16 obd question (sqwale)
usually, you if you have an obd2 car it would be essential to find an obd2 motor, but that dosent always happen. so you could get a obd1 motor, swap injector clips on obd2 harness to obd1 clips, convert the obd1 distro to an obd2 plug, and be on your way....those are the really 2 main issues with that, all of the other plugs are the same ie( vtec/knock sensor/water temp/ oil press/ reverse sensor/ map sensor/ throttle position)....its not really that hard
Old Oct 10, 2005 | 12:21 PM
sqwale's Avatar
Default Re: b16 obd question (JDM1civic)
ah i c is there an advantage having obd1 rather then obd2?
vega_ROCKS
Jul 24, 2020 06:52 AM
KCUF_DB8
May 21, 2010 08:15 AM
topherchris
Sep 26, 2007 07:30 PM
sqwale
Oct 8, 2005 07:39 PM
1man
Jul 21, 2003 11:45 AM
