D-series power steering on LS B18B
Like the title says, i have a Y7 and i am going to do an LS swap, can i resuse my power steering pump and all that or will it not match up? Also, is it becasue the bracket will not line up becasue i can fab a bracket if that is the case.
Re: D-series power steering on LS B18B (racer_X_123)
You can get it to work. I had mine on my 99 LS swapped Civic EX. It it a real close fit but should line up almost the same. I used an LS P/S belt. You have to put it at full tight, but it will still slip a bit. Also the P/S line is a bit shorter than the one on the 99 SI's so it'll be a tight fit. Honestly, it would fit better to use a B-series pump and SI line, but will work.
Tong.Y
04-17-2011 12:06 PM
ohsnapzafingcu
12-08-2008 07:22 AM
