B20vtec Swap, no throttle?!?!? HELP!!!
hey you guys i've just recently drop a b20vtec into my 96 hatch and everything runs fine except that when i go to step on the gas pedel, i get no throttle...i've tried adjust the throttle cable to see if that what the problem but nothing?!?!? the only kinda of rpm accellateration i can get is if i mess w/ the distributor to advance or retard the timing? oh and i also tried unpluging the map sensor n tps on the throttle body while the car runs...but nothin happens? could it be that i have a bad tps or map sensor, because on the throttle body the tps broke, so i just bought a new one off someone and installed it....would that have anything to do w/ it?
Your guys help is really appreciated!!!! THANKS
ATrin
12-10-2005 01:25 PM
SpoonEk253
09-26-2005 12:03 PM
