B18c1 is this worth it....
Old Sep 26, 2005 | 10:25 AM
B18Sleeper's Avatar
Default B18c1 is this worth it....
I found a B18c1 motor with below description for 2900 dollars. Is this a good deal?
94+ GSR (hydraulic clutch) 1797cc 178hp@7600rpm/129 lb-ft@6200rpm. Includes Intake and exhaust manifold, transmission, alternator, distributor, power steering pump, A/C compressor, ECU, and Inner shaft.
Old Sep 26, 2005 | 10:50 AM
B18Sleeper's Avatar
Default Re: B18c1 is this worth it.... (RedlineKustomz)
Can someone help me please? Cause I wanna get it if its a good deal and comes with everything I need.
Old Sep 26, 2005 | 11:57 AM
92Jspec's Avatar
sounds okay..... have you tried searching the classifieds to see how much they go for? i've seen the jdm b18c go for around 3k. also something to consider is the condition of the motor? was it running before it was yanked out? try to get more details on the motor from the seller......
Old Sep 26, 2005 | 12:06 PM
Honda Bull's Avatar
Default Re: B18c1 is this worth it.... (92Jspec)
It should be 170 hp... not 178... if it's the B18C1. And in that case.. you could pick one up for around $2500. A little less or a little more... depending on the location and availability in the area. You could probably be patient and find a much better deal. Ultimately... it's your decision.
Old Sep 26, 2005 | 01:39 PM
B18Sleeper's Avatar
Default Re: B18c1 is this worth it.... (HondaBullSQ)
Well the dealer says it was in a running vechile before it was pulled out. So that is covered. So where should I look for a b18c1 motor? I am rebuilding it anyways so the condition aint that important unless the block was warped or something. Thanks
Old Sep 26, 2005 | 11:11 PM
NerveAgent's Avatar
the deal sounds good to me. If its in good condition.
Old Sep 27, 2005 | 04:46 AM
B18Sleeper's Avatar
Default Re: (NerveAgent)
Thanks I believe I will look around a little longer if nothing cheaper I will order it. Cause it seems like a good deal to me but just seeing what people in here think.
Whitegsr2000
Nov 9, 2010 02:50 PM
phish4709
Dec 6, 2006 05:36 PM
eternalhonda
Apr 30, 2005 07:45 AM
typeRSXS
45
May 4, 2004 05:20 AM
rotorhead187
18
Feb 14, 2004 11:50 AM
