b20vtec; Alternator and throttle cable PROBLEMS!!!!
Old Oct 6, 2005 | 09:46 PM
SpoonEk253's Avatar
Default b20vtec; Alternator and throttle cable PROBLEMS!!!!
Hey you guys i've just recently swap in a b20vtec into my 96 civichatch back and everything is running fine except that I have 2 problems...
<U>PROBLEM #1</U>
SOLVED!
<U>
PROBLEM #2
</U>
when i first start up the car and give it some gas when its in neutral....the rpm raise by it self from 1000-3000 then everything after that i can rev on my own....but when it decelerates it stop's at 1500 n bogs from 1500-1700 back n' forth. The only way i can get it to idle back right is to put my foot under the pettle to decellerate it, I've also tried maybe different times to adjust the throttle cable but that doesnt seem to work and doesnt look like its gettin stuck on anything....any ideas!?!?!
<U>AFTER REPLACING THE THROTTLE BODY AND ADDING A NEW GASKET!
</U>
i dont seem to get any gas newhere before 1500rpm now? the only way for me to get my rpm to raise is to fool it! but when i do that it takes a couple sec than slowly climbs to 1500 ....but everything 1500rpm n beyond i get full throttle and can rev to whatever i want. STRANGE!
Modified by SpoonEk253 at 6:50 AM 10/10/2005
Old Oct 6, 2005 | 10:54 PM
ninjaEF's Avatar
Default Re: b20vtec; Alternator and throttle cable PROBLEMS!!!! (SpoonEk253)
alt belt too loose.... bad "hot wire ground" (the 10mm on the alternator).... check the ground on the engine harness. are you using oem parts?
low coolant level.... bad harness ground.... need to burp the coolant system... clouged iac valve (you can remove it and clean it)
Old Oct 6, 2005 | 11:03 PM
SpoonEk253's Avatar
Default Re: b20vtec; Alternator and throttle cable PROBLEMS!!!! (ninjaek20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninjaek20 &raquo;</TD></TR><TR><TD CLASS="quote">1
Problem 1....I was thinking it could be the hot wire as well...yea im using oem parts...well the only after market things im using is headers, intake...n intake manifold if that makes a diff?
Old Oct 6, 2005 | 11:04 PM
ninjaEF's Avatar
no... check it out it may be getting lose on you and shorting out
Old Oct 6, 2005 | 11:07 PM
ninjaEF's Avatar
if you get a k20a-R then all you're problems are sloved!!!
Old Oct 6, 2005 | 11:14 PM
BIGBLOCKEK's Avatar
Botched thread poll
im sure you already checked but the alternator problem could just be the alternator fuse.
at some time you could have had the hot wire disconnected from the alternator and touched it to the block/frame with the battery still connected.
i've done it.
Old Oct 6, 2005 | 11:22 PM
SpoonEk253's Avatar
Default Re: b20vtec; Alternator and throttle cable PROBLEMS!!!! (BIGBLOCKEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BIGBLOCKEK &raquo;</TD></TR><TR><TD CLASS="quote">im sure you already checked but the alternator problem could just be the alternator fuse.
i've done it.</TD></TR></TABLE>
yea i've check'd the fuse...still good! but i'll double check all my main grounds n hot wire...n see what happens
Old Oct 7, 2005 | 07:02 AM
SpoonEk253's Avatar
ttt
Old Oct 7, 2005 | 07:39 AM
JJ-Built's Avatar
<U>problem 1: </U> check the grounds, alternator belt, starter, anything thats connected to the battery.. fuses..
<U>problem 2:</U> the wire harness on the ecu it might be wired wrong, its dumping too much fuel, adjust the screw on the throttle body (open/close)..
good luck..
Old Oct 7, 2005 | 07:39 PM
SpoonEk253's Avatar
Default Re: b20vtec; Alternator and throttle cable PROBLEMS!!!! (JJ-Built)
well i solved problem #1...now i got the 2nd one still...any more idea's...i might just see if its the throttle body itself...so imma borrow another one to test it out!
Old Oct 7, 2005 | 08:06 PM
ninjaEF's Avatar
vacuum manifold or tb gasket leak... squrit it with a hose while running...you'll see it .....
Old Oct 10, 2005 | 05:44 AM
SpoonEk253's Avatar
well ya guys i've just replace the throttle body it self n got a new gasket n check'd all the hose's to make sure they are connected correctly and they are....now my rpm doesnt bog at 1500 anymore! NOW what its doing is its not letting me get any gas/throttle before 1500 unless i floor it and then my rpm slowly begin to raise after a couple sec....WTF is up w/ that? haha any idea's...
Old Oct 10, 2005 | 05:48 AM
SpoonEk253's Avatar
would the timing have anything to do w/ this...or the fact that i have stage 2 cams or anything like that would be factor?
Old Oct 10, 2005 | 11:58 AM
SpoonEk253's Avatar
ttt
StayKrafty
11
Nov 6, 2022 01:50 PM
truxvi3tz
Mar 31, 2010 02:26 PM
wreckedmyteg
Oct 10, 2008 04:18 PM
SpoonEk253
Nov 23, 2005 07:34 PM
