block info
Old Oct 5, 2005 | 08:07 AM
JDAMC's Avatar
Default block info
I got a b16a 2nd gen with a bad block. And a b16a 1st gen block in the garage. Can i take the guts out of the 2nd gen and put them in the first gen block? Without any problems?
Old Oct 5, 2005 | 02:30 PM
i heart HT's Avatar
Default Re: block info (JDAMC)
Old Oct 5, 2005 | 03:40 PM
unknown0001's Avatar
I honestly don't see why not
both blocks are very much the same. Only thing I could ever think that would change is the valve train for different cams but don't think that's the case.
go for it cheif
Old Oct 5, 2005 | 09:31 PM
98 Spec R's Avatar
Everything is completely interchangebale between those two B16 Blocks.
Old Oct 6, 2005 | 05:25 AM
JDAMC's Avatar
Default Re: block info (98 Spec R)
Thanks guys! Just wanted too check before it was torn down.
Old Oct 6, 2005 | 05:39 AM
RotiEatter's Avatar
Ditto
Whats wrong with the "bad" block?
And if the other block is fine, why not use it? Unless its a bare block?... Just curious.
Old Oct 6, 2005 | 08:55 AM
JDAMC's Avatar
Default Re: (RotiEatter)
one of the cylinders has a ridge. You can see where the rings where. Who knows how long the motor sat? I've only had the swap for about 6 months
T3k C
Dec 4, 2005 05:38 PM
92Jspec
Apr 15, 2005 02:10 PM
B_CRUZ!
Dec 15, 2001 10:08 AM
