Shift linkage problem
Old Oct 1, 2005 | 07:48 PM
Bartman201's Avatar
Default Shift linkage problem
I have a 94 Civic with a B18 swap, i was driving to work tonight and my shifter is was fine till i got to work. i passed over a speed bump and i shift in to 1st but i could not get to lock. the shifter was all lose. what can it be?
Old Oct 1, 2005 | 11:16 PM
Bartman201's Avatar
Default Re: Shift linkage problem (Bartman201)
anyone???
Old Oct 3, 2005 | 05:16 AM
Bartman201's Avatar
help!!!
Old Oct 3, 2005 | 06:43 AM
jdm123's Avatar
you might want to jack the car up and make sure everything on the linkage is still connected all the bolts and the part that goes into the tranny (not sure what it is called).
Old Oct 3, 2005 | 07:14 AM
BlazedD's Avatar
WestSPEC
yescheck the linkage under the car..check the cable by moving it back and forth..
honda trannys are known to give this problem of not always going into first..
if it happened again just go into 2nd first then try puttin gin 1st
Old Oct 3, 2005 | 11:09 AM
Bartman201's Avatar
Default Re: (BlazedD)
thanks. found the problem it was a plate that holds the ball in the bottom of the shifter.
Jay_Mills
Jan 4, 2013 01:30 PM
Dr Blood
May 10, 2006 03:42 PM
1994CivicGS-R
Jan 17, 2006 02:42 PM
Rob!
May 6, 2003 06:19 PM
