Oil Dripping all over the top of the tranny??? where from?
Just noticed today while fixed my master and slave cylinder that my tranny had oil pretty much drenched on the top and it was all over the front of the tranny case by the slave cylinder..
I look around and couldn't see where the oil was coming from... so I just cleaned the oil off the tranny and went to the store in another car and came back like 2hrs later and there was oil running down the top of the tranny... Again!
This ever happen to anyone?
what can be causing the oil leak.?
lemme know what you think.
head gasket, vtec solinoid, cam seal, distributor seal (<--- yikes!), wipe down the tranny and motor with a rag so its all clean. then turn the motor on and run over and look at the motor/tranny. as soon as you can see where its coming from, run over and shut off the motor. you should be able to see where the oil is coming from. just remember to check it all over again once you replace anything. keep in mind you could have miltiple bad gaskets.
Re: (BB6racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6racer »</TD></TR><TR><TD CLASS="quote">head gasket, vtec solinoid, cam seal, distributor seal (<--- yikes!)</TD></TR></TABLE>
thats what i was looking for..
thanks man
atleast i have a starting point now
thanks man
Re: (JoJo1190)
i bet it comin from cam seal take off valve cover that little black plasti seal on exshaust cam next to dizzy take the 4 bolts off clean then apply some type of sealant i like the grey stuff, all the way around the black plastic seal then put 4 screws back in and torque down
drastikmeasurez
07-22-2005 04:59 PM
