JDM CA state ref
Old Sep 23, 2005 | 07:42 AM
astroxtc's Avatar
Default JDM CA state ref
what must you use to state ref a jdm motor?
i was told header, catback, intake manifold, and ecu?
Old Sep 23, 2005 | 10:19 AM
DxTrix's Avatar
Default Re: JDM CA state ref (astroxtc)
All you need is a jdm motor that is the same year or newer then your car, usdm ecu or just the usdm ecu cover, all smog equipment, vacume lines conected corectly and any type of carb legal parts that you want to be included on your bar sticker.
Old Sep 26, 2006 | 01:01 PM
dmefb18's Avatar
Default Re: JDM CA state ref (DxTrix)
up
Old Sep 26, 2006 | 01:07 PM
NJcoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DxTrix &raquo;</TD></TR><TR><TD CLASS="quote">All you need is a jdm motor that is the same year or newer then your car, usdm ecu or just the usdm ecu cover, all smog equipment, vacume lines conected corectly and any type of carb legal parts that you want to be included on your bar sticker. </TD></TR></TABLE>
Old Sep 26, 2006 | 01:33 PM
AnDThEnWuT's Avatar
Default Re: JDM CA state ref (dxcoupe.)
and make sure the car passes emissions! Went to the ref 5 different times because of a faulty cat!
Old Sep 28, 2006 | 12:33 PM
Braco11's Avatar
Default Re: JDM CA state ref (AnDThEnWuT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnDThEnWuT &raquo;</TD></TR><TR><TD CLASS="quote">and make sure the car passes emissions! Went to the ref 5 different times because of a faulty cat!</TD></TR></TABLE>
Good point. Go get pre-test done and make sure you pass the sniffer before you go to the state ref. Makes life way easier.
G_moneydc2
15
Apr 11, 2007 11:02 PM
Noemotion_91DA
Jul 29, 2006 09:12 PM
atmosphere
10
May 14, 2006 12:05 PM
Mr.E.G.
Dec 29, 2004 09:32 AM
Norcalstoppy
Nov 23, 2003 07:10 PM
