LSvtec help
Old Oct 3, 2005 | 10:43 AM
wrx'n you's Avatar
Default LSvtec help
I have a JDM B16 head but its OBD1 going on a OBD1 LS block, i am planning to buy the Golden Eagle LSvtec conversion kit. I heard that i have to do custom wiring and stuff cause of the OBD0 and OBD1 conflict. Is there a wiring kit or anything i can buy for that? besides the golden eagle lsvtec conversion kit, is there anything else i need to buy and what size MM gasket do i need for a stock LS block? 81 MM?
thanks a lot
Old Oct 3, 2005 | 03:48 PM
HondaCivicSiR1's Avatar
Default Re: LSvtec help (Archillion)
Golden Eagle ls/vtec kit is good to use and is fairly cheep look for it on here
Old Oct 3, 2005 | 04:44 PM
wrx'n you's Avatar
Default Re: LSvtec help (HondaCivicSiR1)
what size MM gasket do i need and what about the OBD0-OBD1 wiring?
Old Oct 4, 2005 | 12:11 PM
wrx'n you's Avatar
bump
Old Oct 5, 2005 | 08:07 AM
miller.91.HB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archillion &raquo;</TD></TR><TR><TD CLASS="quote">I have a JDM B16 head but its OBD1 going on a OBD1 LS block</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archillion &raquo;</TD></TR><TR><TD CLASS="quote">What about the OBD0-OBD1 wiring?</TD></TR></TABLE>
Is the car OBD0?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archillion &raquo;</TD></TR><TR><TD CLASS="quote">what size MM gasket do i need</TD></TR></TABLE>
81mm it should come with the kit.
http://www.robearracing.com/pd...l.cfm
Old Oct 5, 2005 | 01:15 PM
wrx'n you's Avatar
the car is obd1 but the head is obd0
Old Oct 5, 2005 | 02:10 PM
unknown0001's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archillion &raquo;</TD></TR><TR><TD CLASS="quote">the car is obd1 but the head is obd0</TD></TR></TABLE>
ok? the kit will still work
Old Oct 5, 2005 | 09:51 PM
wrx'n you's Avatar
Default Re: LSvtec help (Mr.RHTuner)
yeah but how woud i go about wiring the vtec and stuff?
2fast4urass
May 4, 2008 06:55 PM
EG694Si
Nov 30, 2007 03:34 PM
hondaguyef
Mid-Atlantic (Sales)
15
Oct 21, 2005 06:49 PM
TH33G4MON3
Sep 15, 2005 01:12 PM
legacytunes
Apr 6, 2004 05:54 PM
