flywheel install
Old Sep 30, 2005 | 09:21 AM
teler86's Avatar
Default flywheel install
i was wonderin if anybody has a good writeup on how to instal a flywheel on a b16
Old Sep 30, 2005 | 09:29 AM
RotiEatter's Avatar
Ditto
Hmm, I'm not sure but it is extremely easy to do.
Can you change a clutch/
Old Sep 30, 2005 | 09:51 AM
BDBGoalie1982's Avatar
Default Re: (RotiEatter)
Unbolt tranny and remove
Unbolt pressure plate and remove (10mm 12pt i think)
Friction disc will come out w/ pressure plate
Unbolt flywheel and remove/replace(17mm 12pt i think)
Check torque specs before attempting
air tools will come in handy
Old Sep 30, 2005 | 12:52 PM
slomofo's Avatar
GDD Member
Remove 8 bolts, install flywheel, put the 8 bolts back on.
Boom, write up complete, this should be a sticky topic now.
Juan_Mitosis
60
May 20, 2016 07:20 AM
Acidcrakker
Jul 3, 2012 05:35 AM
hon2984
Aug 15, 2008 09:14 AM
Mr.Luder
Oct 17, 2006 01:51 PM
cavrdave
Nov 19, 2004 06:06 AM
