Will USDM parts fit JDM motor?
I am about to purchase a jdm B16a2 and was wondering if usdm parts will fit a jdm motor? I want to replace the waterpump, distributor cap, spark plugs, plug wires and alternator. Which motor should i buy these parts for? Also which gaskets and oil filter will i need? Thanks for the help
Re: Will USDM parts fit JDM motor? (CantGetRich)
Yes, the usdm parts will fit the jdm motor. there is no difference between the motors other than compression ratio and the manifold might have a few different vacum ports.
For timing belt and water pump, get one for a 94-95 del sol vtec (b16a3) or a 99-01 civic si (b16a2). plugs, wires, cap & rotor are usualy all the same for the dohc vtec motors. anything for a b16, b17, b18c should do you fine.
