H22A EK Still Not Starting.
The problem:
No fuel.
Replaced main relay (stock wasn't clicking), still no fuel.
Checked wiring harness.
No voltage is getting to the fuel pump harness.
Should I re-route the fuel pump signal wire to the ECU, or is there anythign else I can try?
No fuel.
Re: (alterdcreations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations »</TD></TR><TR><TD CLASS="quote">THEY MESSED UP</TD></TR></TABLE>
make sure harness under glove box are all pluged in prperly
I'll re-check the conversion harness and make wure all the fittings are good.
If all comes to worse, i'll make a fuel turn off/on switch and run the fuel pump signal straight to the battery.
