K guys i need help!!
Location: Swapin Motors,Tuckin Bays and Making Harness, CT, USfukenA
well i was told by hasport that there mounts will not work on a k20z3, what i want to knoe is if all the k block castings have the same mounting holes as each other, similar to the b series blocks. if this is true can i put those mount brackets from a a2 block and use hasport mounts? thanx in advanced
Re: K guys i need help!! (H22EHSI)
If honda-tech.com cant help you, try http://www.k20a.org
They have all the question for K-series.
Hope that help you out.
Re: (h2b_eg8)
I believe the bell housing for the tranny is the same as the TSX and '05-'06 RSX-S', in which case the mounts won't work for. The mounts with the the '02-'04 transmission, which has a different casing to it. I believe the mounting holes for the tranny still lines up, just the shape is a little different for the mount. Try and find an '02-'04 tranny and swap the Z3's tranny internals and LSD into it.
Re: (H22EHSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22EHSI »</TD></TR><TR><TD CLASS="quote">so the block mounts are the same?</TD></TR></TABLE>
Yes, block mounts are the same, it's the transmission mount which is different. As vtecspeed1320 said, you can modify them to work, or find an 02-04 case and swap internals.
Shooting Star
do you have access to a welder and someone that knows how to use it, and a grinder and maybe a few other things just depends. Never done it just know it can be done.
99TurboBlue
07-09-2007 05:07 AM
ek9jdm
02-04-2006 03:53 PM
phantom_sol
02-24-2004 09:45 AM
