P/S pump and pressure line issues ?
Hey !
Im planning a b16b or a into EK coupe 96 (d16y8 engine).
Usually a p/s pump comes With the new engine, but do i need to replace the p/s pressure line that goes from the top of the pump to the p/s rack ?
If i do need, which pressure line will fit ? the one from the same engine (b16b/a) that im using for the swap, or any pressure line from b16/18 will fit ?
Thanks.
Thanks.
Re: P/S pump and pressure line issues ? (loverboy)
in my 96 civic i am running a 95 gsr motor ps pump and brackets . i had to use a 94 civic pressure line. with some slight modification at the rack
PickleTeg
03-19-2006 06:34 PM
