Axle & CV joint out of place...
well, i was trying to change my clutch and tranny, and when i was pulling out the axels, the one from the driver side, the axle seemed to pop out of the CV Joint, i tryed to push it back in but it didnt budge....anyways...am i going to have to get the axle rebuilt??or can is there a way i can push it bck in??should i try to take the boot off from the CV Joint to see if i can fix it???or am i going to have to take it for a rebuilt???thanks in advance
Re: Axle & CV joint out of place... (B18CivicEH2)
Stand the axle on it's end traight up. Use a regular size hamer and hamer the upper end (to be safe, put a piece of wood on top so you won't damage the threads). It should pop right back in
Re: Axle & CV joint out of place... (CW-ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW-ITR »</TD></TR><TR><TD CLASS="quote">Stand the axle on it's end traight up. Use a regular size hamer and hamer the upper end (to be safe, put a piece of wood on top so you won't damage the threads). It should pop right back in </TD></TR></TABLE>
nice...was thinkin of taking the boot out and try to see whats going on inthere..
I had to remove the boot on mine (what a mess) because the joint came completly apart. I aligned everything, which took some doing and used the above described hammer method.
Zip tied the boot back on and everythings been working fine for some time.
Corksil
11-23-2009 01:30 PM
civcexcoupeblack
09-20-2002 10:04 PM
