D15B7 block / D16Y8 Head OBD1 - dizzy?
I have a D16Y8 head / intake manifold for my D15B7 bottom end. In order to remain OBD1 can I can use the distributor from my D15B7? Is this the only change I need to make?
I searched and it *seemed* to indicate that all I need to do is swap in an OBD1 distributor from any other D series... but I want to be sure before I start hooking things up that the D15B7 distributor would work since it is non-VTEC and I am using a VTEC head.
Thanks in advance.
Thanks in advance.
Go Tigers!
Re: (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">The D15B7 distributor will work fine as it shares the same mounting flange as the Y8 distributor.</TD></TR></TABLE>
EF9_TryMe
03-03-2008 12:39 AM
