throttle sticking
Old Mar 18, 2007 | 02:52 AM
killer hatch's Avatar
Default throttle sticking
i have recently started to have a sticky throttle issue in the last couple of weeks. it doesnt do it all the time but enough to make it very anoying. it only does it after the car is warmed up never when cooled. what happens is when i push in the clutch the rpms will stick at around 2000-3000 rpms. if a brake and bog the car out a little before pushing in the clutch the needle will climb to the same 2000-3000 range. i have to either pull back the gas pedal with my foot or rev to eliminate the issue. i checked the throttle body for rust, bent or worn spring, and nothing is lose. like i said this is extremely anoying help is much appreciated.
Old Mar 19, 2007 | 01:29 PM
dbiker207's Avatar
Default Re: throttle sticking (killer hatch)
lube the throttle cable
chastitymaxwell
Jan 13, 2017 11:01 PM
jksmith
Feb 19, 2009 09:39 AM
E JAY 1
Apr 11, 2008 11:34 AM
97civic123
May 5, 2006 10:44 AM
TheThiefTheKnife'NTheGun
Nov 1, 2005 03:46 AM
