starting issue
Old Apr 6, 2007 | 04:43 PM
dapaur's Avatar
Default starting issue
i got a h22 swapped eg i live in pa so i didnt drive it all winter i started it about once a week for the first month or so but then left it alone i got it up and running now drives fine battery held its charge etc but no when i go to start it i have to give it gas and im not talking like 2 pumps i mean i gotta pump away at the pedal for liek 8-10 secs do you think maybe itsc ause of bad fuel but it drives fine or like my ignition timing or something with my ecu etc any ideas thanks
Old Apr 7, 2007 | 02:09 PM
dapaur's Avatar
Default Re: starting issue (dapaur)
someone
Old Apr 7, 2007 | 08:42 PM
high_revs's Avatar
try to explain it a little better...i think i can help..
Old Apr 8, 2007 | 08:35 AM
dapaur's Avatar
Default Re: (h2b_eg8)
i go to start it i turn the key and all you hear is the starter crank and i always pump gas into a car i start regardless of wheter its wrong or not its a habit before winter it would start right up. now i turn the key and the starter cranks and then i got pump the gas really fast for a good 8-10 secs then it starts. when its first started i have to keep giving it gas for abotu another 2 secs or it idles down and stalls out. i am also having problems with my tps sensor i will put the car in neutral and it will rev from 800 to about 3200 then slowly get softer to a bout 800 to 1200. i figure maybe this has something to do with it i also read somethign about it not compensating for a cold start or maybe my ignition timing i duno. the car runs fine as soon as i had it started and i drove it proably 50 miles no cells but last night the check engine light came on and also i was low on coolantlike bone dry so i duno if that would matter but i think thats my check engine light was on. And it still has the gas in it from sept so maybe just bad gas
jasonlunaa
May 28, 2014 09:06 AM
bdubnyc
11
Apr 30, 2014 12:47 PM
T Rick
Sep 12, 2006 07:32 AM
smash fascism
21
Nov 6, 2005 03:52 PM
turboxsi
Jan 29, 2004 09:06 AM
