what Ecu are you's running on a b16 . P30 or P28
Just wondering cuz i had a P30 and now i have a P28 in and with the P28 my v tec kicks in earlyer but than it redlines somewhere around 7500 .. Does anyone else have this problem ..
Re: what Ecu are you's running on a b16 . P30 or P28 (civicstar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicstar »</TD></TR><TR><TD CLASS="quote">is it chipped, if not, u should get it chipped</TD></TR></TABLE>
dose not matter what ecu you get just as long as it can be chipped/programmed obd1
also i know p30 work best with <crome> or so i have read!
Re: what Ecu are you's running on a b16 . P30 or P28 (DraginTeg93)
YES FINALLY I HAVE THIS SAME PROBLEM. I just bought a swapped b16 usdm eg. p28 ecu redlines between 6700 and 7500 or so. hard to tell cause the steering wheel is right in my view. but yeah what are u using for an rpm gauge. stock or aftermarket? cause i hear the old rpm gauge doesnt work right if you swap engines. also i think the p28 needs to be chipped to work right. sohc vtec to dohc is gonna be alot different. i dont know how to tell if mine was chipped or not. does anyone have pictures of chipped and non chipped p28 ecus? or any similar ecu?
Re: what Ecu are you's running on a b16 . P30 or P28 (richard7968)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richard7968 »</TD></TR><TR><TD CLASS="quote">
also i know p30 work best with <crome> or so i have read! </TD></TR></TABLE>
P28 ecu can use P30 maps so the only difference among those two is that the p30 have a knock board.
Simple_Works
Engine Management and Tuning
01-07-2018 07:20 AM
