H22 doodes needed..VTEC codes and stuff
Old Apr 8, 2007 | 06:28 PM
The Destroyer's Avatar
Default H22 doodes needed..VTEC codes and stuff
Alright suckas,
Here's the damage.. ya ming.
H22 swapped EG p06 chipped w/ Crome (turbogizzer tuned) throwing code 21.
I have No vtec, oil level is fine, vtec solenoid has been tested and is ok . I tryed looping a4 to d6 and that didnt work (actually made throw code 22 too). I have swapped vtec pressure switches with another working one and that had no luck either . Vtec screen is clean.
Give me some ideas here pleaaase
Old Apr 8, 2007 | 06:44 PM
high_revs's Avatar
did you wire vtec yourself?
Old Apr 8, 2007 | 06:46 PM
Default Re: (h2b_eg8)
Yeah its worked for the longest time.
I was swapping roms with my buddy last weekend all weekend and its been giving me trouble since.
Old Apr 8, 2007 | 06:50 PM
Lan's Avatar
Lan
Default Re: H22 doodes needed..VTEC codes and stuff (..Eric..)
Kenny burnt you a chip w/o VTECH BWAGAHAHAHAHHAA
high_revs's Avatar
so it was fine with this exact ecu...then you switched chips are it stopped working? prob f*cked up the ecu...
Old Apr 8, 2007 | 07:18 PM
Default Re: H22 doodes needed..VTEC codes and stuff (Lan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lan &raquo;</TD></TR><TR><TD CLASS="quote">Kenny burnt you a chip w/o VTECH BWAGAHAHAHAHHAA </TD></TR></TABLE>
Haha screw you. Its a good chip I swear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2b_eg8 &raquo;</TD></TR><TR><TD CLASS="quote">so it was fine with this exact ecu...then you switched chips are it stopped working? prob f*cked up the ecu...</TD></TR></TABLE>
No the ecu is fine, we tested it on another car.
Modified by ..Eric.. at 10:19 AM 4/9/2007
gotslicks
Nov 26, 2006 03:44 AM
Novtecdohc
Nov 15, 2006 09:16 PM
1point7db2
Sep 21, 2004 03:08 PM
HRDCORD
Jun 21, 2004 10:23 PM
H22AJSPEC
Sep 10, 2003 08:33 PM
