--NEED HELP-- ELECTRICAL LOAD DETECTOR!!!!
could it be the ELD?
i have a 91 civic hatchback si
how do i fix this ? i dont know even know where to begin!
when i start my car, the car seems like its bout to just die and give out on me
and when in 2nd gear, once i past 3000 rpm my check engine light comes on
or when i have my headlights on, press on the brakes, or signal
please help me !!!
Modified by diegospecaccord at 5:51 PM 4/4/2007
please help me !!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lightcrx »</TD></TR><TR><TD CLASS="quote">eld is in the underhood fusebox, you need to get a new fuse box if this sensor goes bad.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lightcrx »</TD></TR><TR><TD CLASS="quote">eld is in the underhood fusebox, you need to get a new fuse box if this sensor goes bad.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lightcrx »</TD></TR><TR><TD CLASS="quote">eld is in the underhood fusebox, you need to get a new fuse box if this sensor goes bad.</TD></TR></TABLE>
alright i'll check that out thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris »</TD></TR><TR><TD CLASS="quote">Is the car stock?</TD></TR></TABLE>
yes the car is stock..bone stock
Something could be grounding out somewhere.
I had this happen to me in my stock EG.
Check all the wires and make sure there not touching anything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReDemoN »</TD></TR><TR><TD CLASS="quote">Something could be grounding out somewhere.
Check all the wires and make sure there not touching anything.</TD></TR></TABLE>
i'll checc it out thanks
crx_gsr_vtec
Dec 4, 2006 06:56 PM
