b20vtec????
Old Mar 22, 2007 | 02:27 PM
hspoon's Avatar
Default b20vtec????
wat kinda head gasket do i need if i use a b16 or gsr head???... is there any difference to make a ls vtec and a b20vtec..????
thanx
Old Mar 22, 2007 | 09:24 PM
jizzay34's Avatar
Default Re: b20vtec???? (hspoon)
if you build a b20/vtec use a b20 headgasket(84mm) for the ls/vtec use ls head gasket(81mm). the head is your option. most people use the b16/or b18c5 because of the intake manifold. no iabs to activate as with using a gsr head.
Old Mar 23, 2007 | 09:52 PM
smileycvc's Avatar
Default Re: b20vtec???? (jizzay34)
^^ wow you really are a noob. You cant just run a factory b20 headgasket. When you use a b20 block you need the vtec dowel pins, you also need a modified b20 headgasket to accomidate for the pins. Golden eagle sells them for about 80 bucks I think.
Old Mar 24, 2007 | 08:39 AM
jizzay34's Avatar
wrong!!! u can use a stock b20 headgasket if you machine the head for the dowel pins. i know this becacause im runnin a b20 vtec. this was being done long before golden eagle came out with their kit. b20/vtec runnin strong after 3 yrs. hmmm noob! (just to this sight).
Old Mar 25, 2007 | 10:49 AM
hspoon's Avatar
Default Re: (jizzay34)
machine the head for the dowel pins????... wat exactly u have machine... ??? never done a b20vtec or ls... thanx....
Old Apr 4, 2007 | 10:14 AM
jizzay34's Avatar
Default Re: (hspoon)
machine the head for the dowel pins and vtec oil hole. i would also suggest a block gaurd because the b20 block is gonna see alot more revs than it's used too.
ss396rat
Aug 22, 2009 09:00 AM
cheztaboi
Jan 27, 2008 01:16 PM
95jdmdc4
Jun 22, 2006 09:04 PM
Pandahatch
May 5, 2004 12:05 PM
Special B
Dec 17, 2003 08:58 AM
