Final Preparations for my B16 swap
Ok so im almost done with everything i need for my swap. i will be changing the clutch on it along with the cam gears that i hope to pick up this week. also some axles that i hope to find from a 90-93 teg. now let me give you a little more info. this swap would be goin in my 95 dx that already has a 93 ex vtec swap. so first off, tranny & clutch: both are hydro so there shouldnt be a problem right. and like i mentioned, axles will be swapped out for the teg ones. headers: the new engine is a 95 jdm b16 sirII, so stock exhaust manifold does not have a place for the o2 sensor. can i use my stock headers from the current d16? til ofcourse i save up more money to get aftermarket ones. harness: can i get a away with using the current wiring harness? since my car is a dx, its already set up for vtec cuz it been swaped. well i have a bit more things that i want to clear up but i wont throw them all out at once. so please comment on this guys. thanx in advance.
Re: Final Preparations for my B16 swap (sirminder)
ok first, you need axles from a 94+ integra. im not sure if the 90-93 ones will work so just get ones that are garunteed.
no worries with the slave cylinder (for clutch) it works fine.
use the stock JDM b16a header. the one from the d16 wont work, there should be a spot on the second pipe comming off the header.thats where mine was, about 2 inches from where the cat connects.
yes use your dx harness with vtec wired. shouldnt have a problem
Re: Final Preparations for my B16 swap (KAMiN)
thanx kamin. i guess ill have to tapp off the O2 wires and make and extend the wires to fit down the other hole u mentioned. i dont have the engine with me, its at a shop. so ill have to go by what u say cuz i dont remember seeing that. thanx again. keep them coming guys, i this board. oh yah almost forgot, the axles. well i brought up 90-93 cuz some one had mentioned that to me. so im gonna need a bit more clarification on that.
[Modified by sirminder, 1:23 AM 4/15/2002]
Re: Final Preparations for my B16 swap (SpooN Man)
yes b16 axles would work (provided there from a del slo or integra)
im pretty sure all b series axles are the same
hondatuner020
12
12-27-2007 06:32 AM
freak86
10-20-2006 07:51 PM
b16 swap need to swap the 89dx hubs for 91 teg hubs for the axles PLEASE HHHHHEEELLLPPPPP...........
4gencivicef9
Suspension & Brakes
04-10-2006 10:23 AM
