smog in cali
Old Apr 14, 2002 | 03:34 PM
boxcar_racer9's Avatar
Default smog in cali
How do you guys in cali pass your smog test with your hybrids besides paying someone off. I really don't have anyone that i can pay off. do i swap the stock back in everytime in need a smog or what? help me out here. i would hate to be stuck with my stock engine.
Old Apr 14, 2002 | 04:24 PM
B16CRX's Avatar
Default Re: smog in cali (boxcar_racer9)
It is getting harder to pass legally everyday.
Basically, this is supposed to be what you need to pass.
Engine is the same year or newer than the car. Also must be a USDM engine. All emmisions equipment for the engine must be installed properly and working. I think thats it, but feel like I might be forgeting something.
Visual is the hard part. Try a few different places. They might not notice or might not care as long as you pass the tail pipe.
[Modified by B16CRX, 5:24 PM 4/14/2002]
Old Apr 14, 2002 | 05:40 PM
TRAY's Avatar
Default Re: smog in cali (B16CRX)
register your car in a non-smog county....Thats what i did with mine. My mom lives in a non smog county so i put the car in her name. I think it may even work with a PO box
Old Apr 14, 2002 | 09:30 PM
GokuSSJ4's Avatar
Default Re: smog in cali (TrayDay2K1)
and that would be where ?
Old Apr 15, 2002 | 07:26 AM
Spade's Avatar
Read sig.......
Old Apr 15, 2002 | 01:49 PM
TRAY's Avatar
Default Re: smog in cali (Spoon1)
If your talking to me....Bishop, CA is where I regestered my car...The town is so small that they dont have a smog station so there is no smog checks
Old Apr 15, 2002 | 02:41 PM
irev210's Avatar
Im just confused as to why people think it needs to be a USDM motor.
Japanese Replacement Engines
Used engines imported from Japan can be used as replacement engines as long as the engine being used has been identified as functionally identical to the original engine. Please refer to the engine importers catalogue to determine if a replacement engine is legal for installation in your vehicle.
Basicly, if u meet the USDM/CALIFORNIA smog regulations thata re on original USDM PRELUDES or USDM GSR's ur fine.
look
The following list will help you determine if a part for your vehicle is a replacement part and legal for use on pollution. Check the manufacturer's catalogue to verify vehicle application and look for disclaimers, such as "Not legal for street use in California".
Air Cleaner
Most emission controlled vehicles will have an air cleaner that is a closed element type or thermostatically controlled. A replacement air cleaner must meet the same specifications as the original and connect to any emissions equipment that was attached to the original equipment air cleaner. Any replacement air cleaner elements may be used as long as they meet original factory specifications. Any air cleaner that does not meet the original factory specifications requires an Executive Order to be legal for street use.
Cams
The manufacturer of replacement cams determines which of their parts are considered replacements for original equipment. These replacement cams are then listed by vehicle year, make, model and engine size in the manufacturer's catalogue. A replacement cam must have exactly the same specifications (grind) as the original part. Cams that have different specifications than the original part require an Executive Order to be legal for street use.
Carburetors
The manufacturer of replacement carburetors determines which of their models are considered replacements for original equipment. These replacement carburetors are then listed by vehicle year, make, model and engine size in the manufacturer's catalogue. Carburetors not listed as replacement parts by their manufacturer must have an Executive Order to be legal for street use.
Catalytic Converters
A legal aftermarket catalyst is one that is listed in an ARB approved manufacturers catalogue for the year, make, model, and engine size of vehicle on which it is being installed. Manufacturers of aftermarket catalytic converters must obtain an Executive Order for their products from the Air Resources Board in order to be listed in an approved catalogue.
Coils and Ignition Wires
Any type of coil or ignition wires may be used as long as they meet original manufacturer specifications.
Computer Chips
Replacement computer chips must be an original equipment manufacturer part. Aftermarket computer chips must have an Executive Order to be legal for street use.
Electronic Ignitions
The manufacturer of replacement electronic ignitions determines which of their models are considered replacements for original equipment. These replacement electronic ignitions are then listed by vehicle year, make, model and engine size in the manufacturer's catalogue. Electronic ignitions or electronic point replacement units for vehicles not originally equipped with these items require an Executive Order to be legal for street use. Swapping electronic ignitions from different years, engines, or makes is illegal.
Distributors
The manufacturer of a replacement distributor determines which of their models are considered replacements for original equipment. These replacement distributors are then listed by vehicle year, make, model and engine size in the manufacturer's catalogue. Swapping distributors from different years, engines or makes is illegal. Aftermarket distributors that are not listed as replacements for the original part require an Executive Order number to be legal for street use.
Fuel Injection
The manufacturer of replacement fuel injection systems determines which of their systems are considered replacements for original equipment. These replacement fuel injection systems are then listed by vehicle year, make, model and engine size in the manufacturer's catalogue. Fuel injection systems not listed as replacement parts require an Executive Order to be legal. Modifications that change a vehicle from fuel injection to carburetion or from carburetion to fuel injection also require an Executive Order to be legal.
Fuel Tanks
Replacement fuel tanks must be identical to the original part. Add-on fuel tanks, or tanks with greater capacity than the original tank are legal for street use only if they have been issued an Executive Order.
Heads
Replacement heads must be identical to the original part. Head swaps from different years, engines or makes are illegal. Aftermarket heads or valve train components that are not made to the same specifications as the original parts require an Executive Order to be legal for street use.
Headers
Non-catalytic Converter Equipped Vehicles
Headers for non-catalyst equipped vehicles are considered legal replacement parts as long the replacement header allows for the installation of all smog control equipment originally attached to the stock exhaust manifold. Depending on the vehicle, some of the equipment that would normally be attached to the exhaust manifold includes:
Air injectors
Heat shields for the thermostatic air cleaner
Heat risers
EGR system hookups
Fuel evaporation systems
Catalytic Converter Equipped Vehicles
Headers for use on catalytic converter equipped vehicles require an Executive Order to be legal for street use.
Intake Manifolds
The manufacturer of replacement manifolds determines which of their models are considered replacements for original equipment. These replacement manifolds are then listed by vehicle year, make, model and engine size in the manufacturer's catalogue.
Replacement manifolds may be made of a different material than the original part, for example polished aluminium instead of cast iron, but the design of the casting must be the same. Any manifold not listed as replacement part by its manufacturer must have an Executive Order to be legal for street use.
Carburetor adapter plates are not legal unless they are an integral part of a replacement manifold.
Other Internal Engine Parts
Replacement internal engine parts, such as pistons, rods, or the crank, must be designed to factory specifications. Oversize parts can be used as long as they are within factory tolerances for replacement engine parts. Any part not built within factory specifications requires an Executive Order to be legal for street use.
Transmission or Transaxle
Transmissions and transaxles changes alone are not legal. Transmissions and transaxles can only be changed along with their matching engine. The total engine transmission package must conform to the engine change requirements above.
Replacement Engines
Entire engines can be replacement parts. As with any other replacement part, the engine must be identical to the original. If the replacement block or engine is obtained without emissions equipment, all the equipment from the original engine must be installed on the replacement block.
If the engine is not identical to the original then it is not a replacement part, instead it is considered an engine change.
Engine changes are a modification that must meet certain requirements to be legal (please see "Engine Changes").
Engine Changes
Engine changes are legal as long as the following requirements are met to ensure that the change does not increase pollution from the vehicle:
The engine must be the same year or newer than the vehicle.
The engine must be from the same type of vehicle (passenger car, light-duty truck, heavy- duty truck, etc.) based on gross vehicle weight.
If the vehicle is a California certified vehicle then the engine must also be a California certified engine.
All emissions control equipment must remain on the installed engine.
After an engine change, vehicles must first be inspected by a state referee station. The vehicle will be inspected to ensure that all the equipment required is in place, and vehicle will be emissions tested subject to the specifications of the installed engine.
All you do is need to make sure ur JDM engines have US emissions. IE: drive untill u get sent to a ref, and just go to a junkyard and buy the emissions equimpent u need, 100 dollars would cover.
[Modified by sirhatchback, 11:43 PM 4/15/2002]
Old Apr 15, 2002 | 07:48 PM
the reason i ask is because my friends buddy is willing to sell me a b18c5 engine low miles built up and all the goodies for around $2500 installed. i was just wondering if it would all be worth it going into a 92 civic hb
K i l l a B e e.
Jul 19, 2005 01:28 PM
civura R
Jan 5, 2003 05:39 PM
YellowCivic95
Apr 24, 2002 08:54 AM
boxcar_racer9
11
Apr 15, 2002 11:06 PM
