Knock sensors with CRVTEC
I read everything over at CRVTEC.com and couldn't find anything about the knock sensor. Is it true that with CRVTEC you dont run a knock sensor?
Same with LS/VTEC?
Doing this CRVTEC seems pretty complicated to me. Here's my my question. I'm going to do a swap into an EG hatch in the next couple months. If my plan is to run N20 initially, then eventually rebuild and run a turbo....am I better off just going with a B18C1, or actually building a CRVTEC or LS/VTEC ?
Same with LS/VTEC?
Re: Knock sensors with CRVTEC (misledyouth)
But isn't it dangerous to not have one? What if you get a bad tank of gas?
My question is, is there a way to have one hooked up?
I'd be running a turbo eventually and maybe n20 before that, or together. Seems like a knock sensor is good idea
Re: Knock sensors with CRVTEC (16vracer)
b20's do have a Knock senser
I't my understanding that when they chip the p28 it will cause your
check engine light to be on all the time so they program the ecu to
not see the the knock sensor
someone please corect me if i'm wrong
Re: Knock sensors with CRVTEC (rolow)
Someone please correct me if i'm wrong, but doesn't the computer need a knock sensor in order to determine if VTec should be engaged? BTW, all B20 and LS blocks have knock sensors...
B96v6
B96v6
Re: Knock sensors with CRVTEC (B96v6)
I was just going by what that book Honda and Acura Engine Builders Guide said. They said you have to ground the knock sensor wire to the chassis so that ECU is fooled and let's VTEC engage.
That's all fine and dandy for VTEC, but I want a working knock sensor.
So there is no way to make it function?
Or you can keep your ears open and use good gas
91 octane and the az heat have given me alot of problems thats why i got the j&s
[Modified by rolow, 3:10 PM 4/13/2002]
B20 Z has a knock sensor/ b20b does not
http://hybrid.honda-perf.org/tech/b20/b20tech.html
Im running a gs-r ecu w/ my b20. So that ecu has a a knock sensor, mine is just taped up in pass. compartment. Until i get my p28 reprogramed.
civicsi4life
06-14-2004 02:46 PM
