Anyone in a CRVTEC-equipped EF ?
Re: Anyone in a CRVTEC-equipped EF ? (from_zer0)
My 89 crx should be crvtec equipped in about a month as soon as I recieve my new water pump, timing belt, rod bearings and R cams. Also, I need a tranny and axles. Why? Do you have questions?
Re: Anyone in a CRVTEC-equipped EF ? (Jeff C)
I can answer any questions as well.
Re: Anyone in a CRVTEC-equipped EF ? (badCRX)
are you getting the head chambers opened up to suit the 84mm bore?
are these technically called the quench areas?
t..
t..
Re: Anyone in a CRVTEC-equipped EF ? (tinkerbell)
90 si hatch> crvtec < b20z with b18c1 head 13:1, skunk stage 3's and some other junk, yea it will be a somewhat daliy driver
Re: Anyone in a CRVTEC-equipped EF ? (dohcsideSi)
leave the chambers on the head alone when it comes to matching the cylinder aperture - according to Tom Fujita of Portflow fame.....
Re: Anyone in a CRVTEC-equipped EF ? (Ruby Civic)
Re: Anyone in a CRVTEC-equipped EF ? (daver)
yes, it does not seem to affect (improve) combustion any, although obviously he does a great job on the bowl work.........he will do it but does not recommend it as it surprisingly does not seem to affect performance other than not losing compression as you suggest....that came up because I had thought of just the same thing and he advised me so - going CRVTEC within this next month I hope.
well, sounds like some good advice from an experienced engine builder. Did he give you any recomendations for safe crvtec redlines with the stock bottom end?
d
d
hobojoe
12
02-19-2013 12:50 PM
