B16 brackets?
Old Apr 18, 2002 | 08:04 AM
Hayasa15's Avatar
Default B16 brackets?
I read the Hasport site and it said to use a different lest side bracket. I am assuming that is connected to the engine. Do i need one from a 90-93 integra? Just to clarify something, i can use 90-93 integra axles but it depends on the intermediate shaft, and i am assuming that that depends on which tranny i use. Am I correct? One last question. Should i buy an aftermarket linkage or just shorten an integra linkage? This swap is going in a 90 civic if you were wondering.
Old Apr 18, 2002 | 08:56 AM
EP3_05's Avatar
Default Re: B16 brackets? (Hayasa15)
You will need a 90-93 integra rear bracket. The bracket connects to the rear mount and the engine/trans. You can use 90-93 integra axles depending on what intermediate shaft you have, not on what trans. Sometimes you get a swap that will not come with an intermediate shaft. I would suggest using a 90-93 integra intermediate shaft and axles if the swap does not come with them. I bought an aftermarket linkage but if you want to save money and know a welder, then shorten the integra linkage.
Old Apr 18, 2002 | 02:27 PM
Hayasa15's Avatar
Default Re: B16 brackets? (91civic)
What about the drivers side engine bracket? Do i need one from an integra? I am using a b16 from a del sol or a 2000 si if it matters.
Old Apr 18, 2002 | 02:32 PM
EP3_05's Avatar
Ok thanks for mentioning that You will need a drivers side bracket from 1 90-93 integra also.
integrawow
May 26, 2007 07:46 AM
.Grimace
Sep 29, 2005 08:28 AM
XANDER-666
Oct 7, 2002 12:04 PM
TurboMiata
May 13, 2001 04:01 PM
