Ls/Vtec HELP!!!
Old Apr 17, 2002 | 03:16 PM
Teg15's Avatar
Default Ls/Vtec HELP!!!
I bought some Eagle connecting rods and wanted to put some b16a (pr3) pistons on them but the machine shop said that I need floating pistons. They also said something about the connecting rod bushings. Does anyone know what they are talking about?
Old Apr 17, 2002 | 08:30 PM
sleeper4dr's Avatar
Default Re: Ls/Vtec HELP!!! (Teg15)
yeah.. Honda OE pistons use a pressed pin to hold the pistons onto the rods. these pins HAVE to be pressed into the rods/pistons.
the Eagle rods use a floating pin. you can slide the pin in yourself using a floating pin (which is secured with c-clips). you cannot use Eagle rods with Honda OE pistons. you need aftermarket pistons like Ross or JE for example.
Old Apr 18, 2002 | 05:10 AM
broke1's Avatar
Default Re: Ls/Vtec HELP!!! (sleeper4dr)
damn i didn't know that. so what after-market rods would you use with ctr pistons?
Old Apr 18, 2002 | 10:10 AM
Bleed Black's Avatar
Default Re: Ls/Vtec HELP!!! (broke1)
With the LS block and CTR pistons you'll only be able to use LS rods.
Old Apr 18, 2002 | 02:53 PM
Teg15's Avatar
Thanks sleeper4dr, I guess I'll have to get aftermarket pistons then
Old Apr 19, 2002 | 05:05 PM
Teg15's Avatar
Hey, does it matter if I get aftermarket pistons for a b16a or b18a?
Old Apr 19, 2002 | 05:12 PM
bruthaboost's Avatar
Guy, it would be hundreds cheaper to buy ls rods and have them pressed in. Pistons and rings will run you around 500+, however you'll be able to get 12.5 compression. If you do decide on forged pistons, get some that are 20 thou over. With the ls stroke, you displacement should be around 1850cc I think. Anywho, I'll give you my ls rods for 50 shipped if you want em.
Old Apr 19, 2002 | 05:27 PM
Teg15's Avatar
Default Re: Ls/Vtec HELP!!! (b18bpwr)
I have eagle rods and just wanted to know if there is a difference between b16a and b18a piston. Oh, no thanks on the ls rods.
Old Apr 21, 2002 | 06:10 AM
Teg15's Avatar
Default Re: Ls/Vtec HELP!!! (C5_ALLMOTOR)
Thanks man.
thehatchninja
Dec 12, 2006 02:25 PM
model x
Dec 5, 2005 06:45 PM
hotimportcrx
10
Sep 6, 2005 10:39 PM
