B16 in 1st gen crx-in progress need help with fuel and vaccum connections
Please post any pics you have of the engine bay. I would like to see the connections coming off the intake manifold.
HELP!
HELP!
Re: B16 in 1st gen crx-in progress need help with fuel and vaccum connections (slownslc)
which connections in particular?
(also try doing a search on 'vacuum diagram')
t..
t..
Re: B16 in 1st gen crx-in progress need help with fuel and vaccum connections (tinkerbell)
yeah there is only coolent to the bottom of the tb.
fpr vacume line front right of the manifold..
pcv line (midddle of intake manifold)
and brake booster( back of manifold).
the MAP sensor should attach to a small hose attached to one of the metal tubes that run along the top of the back of the plenum and attaches to another small hose that plugs into the top of the throttle body...
this may help
t..
this may help
t..
also this pic of the MAP sensor and my beautiful surge tank/fuel system:
HTH,
t..
HTH,
t..
Can someone please show me where this vaccum line is going? It isnt connected to anything on mine...
Re: (calgone47)
I have an AEM intake on mine and the only connection it has is to the valve cover. Should I buy a t fitting and connect that vaccum to another hose? IF so which one? Would it have any effect on my car for this to be disconnected?
TIA
TIA
tempsohc
06-19-2011 06:06 PM
brokenojoke
09-10-2004 08:22 PM
