Can a 92-95 Si Head fit a 92 CX block?
Re: Can a 92-95 Si Head fit a 92 CX block? (CivicHB_92)
yes but u might wanna change those pistons..the 92-95 cx block is an 8 valve motor..with only 2 valve reliefs on each piston...with the 16v head u might wanna invest in pistons that tolerate all 16 valves
[Modified by JaeOne3345, 1:09 AM 4/18/2002]
Re: Can a 92-95 Si Head fit a 92 CX block? (JaeOne3345)
yes you can use ythe pistons from the SI, you can also use the pistons from a DOHC ZC..i hear this will create more compersion?
Has anyone done this before? If so, how did it turn out? and anything you can tell me what to look for while doing it.
thanks
thanks
bazookatooth
04-15-2005 09:55 AM
