help... b16a2 obd1, ecu code 14
Old Apr 10, 2002 | 06:20 PM
stockegsix's Avatar
Default help... b16a2 obd1, ecu code 14
i'm having a problem with my swap, ecu is throwing code 14, Idle Air Control(IAC) Valve. i'm using my stock 97 dx harness w/ skunk2 obd2-obd1 harness
how do i fix this? thankx
Old Apr 10, 2002 | 06:24 PM
DR. ON POINT's Avatar
Banned
Default Re: help... b16a2 obd1, ecu code 14 (silversleeper)
u have to repin a14 to 12
Old Apr 10, 2002 | 06:59 PM
stockegsix's Avatar
Default Re: help... b16a2 obd1, ecu code 14 (On Point EK)
do you have any diagram? or know any link for it?
Old Apr 10, 2002 | 07:12 PM
9495accord's Avatar
http://www.hondata.com/techwiringpw0.html
Old Apr 10, 2002 | 07:17 PM
stockegsix's Avatar
Default Re: help... b16a2 obd1, ecu code 14 (9495accord)
i actually have a p28 ecu w/ skunk2 chip, please need help with wiring
Old Apr 10, 2002 | 09:30 PM
Soku1kcivic's Avatar
Get a ITR ECU P73 it will slove the problem because it slove mined for my SOHC VTEC
Old Apr 10, 2002 | 10:45 PM
Jaker's Avatar
The first guy that answered is totally correct.
Your DX engine wiring harness has the IACV (Code14) wire attached to pin A14, and the adapter has the wire attached to pin A12. You have to move the wire on the engine harness from socket A14 to socket A12. The connector that you should concern youself with is the one that plugs into your adapter in the car. This connector has 32 pins. It is the biggest of the 3 connectors. If you look at the connector from the side that the wires are on, and with the release tab at the top, the 2nd row of pins is A12 to A24. You need to move the wire from A14 (the 3rd one in from the left) to A12 (the first position on the 2nd row).
Do this, and your code 14 will be gone, and the car will idle much better when the engine is cold.
Old Apr 11, 2002 | 06:09 AM
Banned
Default Re: help... b16a2 obd1, ecu code 14 (Jaker)
like I said....I am the ******* man
Old Apr 12, 2002 | 12:16 AM
stockegsix's Avatar
jaker, one point ek you guys rock!!!
Old Apr 12, 2002 | 06:04 AM
Banned
well than ebeer for us : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : :
Old Apr 12, 2002 | 11:20 PM
stockegsix's Avatar
YEAH!!! it worked... no more check engine light. thanks for lookin out man. although i couldn't get the a14 pin out, me and my friend just spliced the a14 black wire from the engine harness and connected a wire to the a12 wire of the convertion harness. it works ok. my car idles much better it also runs better. next is my suspention...
doctorake
Mar 25, 2012 08:01 AM
SoFreshh
Dec 7, 2009 10:08 PM
lsvtec hf
Aug 25, 2009 07:29 AM
SiR Inspired ED7
May 6, 2008 08:24 PM
