b20/vtec vs b18b/vtec
Old Apr 13, 2002 | 11:43 PM
willyboyK20's Avatar
Default b20/vtec vs b18b/vtec
I know the b20 will make more power but i wanted to know around how much more. with both blocks just having ctr pistons and a b16 head, stock cams, ecu, etc, how much hp to the wheels would either engine make
if anyone knows can u post up some numbers. thanks.
Old Apr 14, 2002 | 03:55 AM
tinkerbell's Avatar
Default Re: b20/vtec vs b18b/vtec (willyboyD16)
how r you using ctr pistons?
are you using a B20A block?
[Modified by tinkerbell, 12:57 PM 4/14/2002]
Old Apr 14, 2002 | 06:26 AM
CRX_VTEC's Avatar
Default Re: b20/vtec vs b18b/vtec (tinkerbell)
What kinda CTR pistons fit in a B20????
Old Apr 14, 2002 | 06:33 AM
B16CRX's Avatar
Default Re: b20/vtec vs b18b/vtec (CRX_VTEC)
They don't. B20 is 84mm bore. All other Bseries are 81mm.
Just won't work.
Old Apr 14, 2002 | 04:03 PM
tinkerbell's Avatar
Default Re: b20/vtec vs b18b/vtec (B16CRX)
the B20A has a 81mm bore...
Old Apr 14, 2002 | 04:16 PM
B16CRX's Avatar
True, I was just assuming it was B20B or B20Z if it was for B20VTEC.
Old Apr 14, 2002 | 07:29 PM
i mentioned the ctr pistons because a website i visted said they could machine the block to accept the ctr bigger pistons
Old Apr 14, 2002 | 07:35 PM
tinkerbell's Avatar
we seem to have a breakdown in understanding here.
teh ctr pistons are SMALLER than the B20B pistons.
the ctr pistons are suited for an 81mm bore, teh B20B/Z has a bore of 84mm.
hence more displacement and potential for power...
t..
Old Apr 14, 2002 | 11:32 PM
RexB16's Avatar
b18 and b20 blocks are the same, so theoretically a b18 could put out just as much power with a wee bit 'o machine work.
Old Apr 14, 2002 | 11:36 PM
RexB16's Avatar
Default Re: b20/vtec vs b18b/vtec (RexB16)
and i have some#'s for you
two friends:
ls/vtec
b16 head
ctr cams
itr intake mani
dc header
b16 pistons
178 whp (no tuning)
b20/vtec
b16head
port/polish head
ctr cams
jdm itr header
stock block
174 whp (no tuning) 191 whp after vafc and tuning (no additional mods)
Old Apr 15, 2002 | 04:11 AM
CRX_VTEC's Avatar
the major difference is in the torque the B20 has.
Old Apr 15, 2002 | 06:03 AM
Finest's Avatar
Resleeve the B18 to 84mm and you have a B20.
So if you're staying N/A, go with the B20 since it has a big bore...and I don't see a need to resleeve if you're just going with bolt ons. But if you're planning on FI in the future, and planning on boosting 10-20psi, then you'll need to resleeve anyways. The B18b is plentiful and cheap, so you can find one really cheap and resleeve that to 84mm. Same as if you would resleeve a B20 to stock bore. Starting with a B18b block would save you a few bucks down the road.
Old Apr 15, 2002 | 03:16 PM
tinkerbell's Avatar
Default Re: b20/vtec vs b18b/vtec (Prelude_RCR)
doesnt the B20 have different jackets?
the one piece design?
correct me if im wrong, but that is the major advantage of the B20,
it is stronger than all other B series blocks?
otherwise we could all just bore our B16's to 84mm?
a B18 block bored to 84mm would NOT be as strong as a stock B20...
t..
Old Apr 15, 2002 | 05:14 PM
from_zer0's Avatar
Too lazy to check the facts, but...
I believe the b20 does have a different setup. It's cast so that there's one piece for the 4 cylinders vs. individual cylinder sleeves or something like that. (This is all what I recall, and theory, I've never personally dealt w/it) Basically it's more solid and better at dispersing heat.
Can't remeber exact #s, but someone mentioned HP figures for a LS-V vs. CRVTEC...What were the TQ #s ? Just curious...for instance, a cammed, modded b16 against a LS-V of the same, the 1.8 was putting out 10 more HP, but 30+ TQ!
That's gonna make quite a bit of difference in the 2 motors, even though they're only ~.2L difference in displacement.
Just trying to chime in and maybe contribute something useful. Why NOT go with more displacement in the SAME block? Gotta love the B-series motors, gotta hate the lack of TQ. Here's the solution.
Oh, and to answer the original Q about HP/TQ #s, just from a few dynos I've looked over the 1.8 averages 130-140 TQ to the wheels whereas the the 2.0 motors are more around 155-160 @ the wheels. Hosepower as low as 175ish up to 230+ for the 1.8, the 2.0 motors are consistently in the 200+ WHP range, up to the 240+ area. These are just guesstimates, anyone wanna add/subtract anything?
Thanks for your time.
[Modified by from_zer0, 2:30 AM 4/16/2002]
Old Apr 15, 2002 | 09:12 PM
silver89civic's Avatar
Default Re: b20/vtec vs b18b/vtec (from_zer0)
What about turbo? Which one is better B20B or B18B?? Would you put some specifications?
I mean to get to do 10secs on a 1/4 mile with a 4g, and is it true that the B20B is more expensive? Cuz one shop quoted me $3000 to do a full swap of a B20B.
Old Apr 16, 2002 | 06:39 AM
Finest's Avatar
That sounds about right. I've seen some with less, but on the average around that ballpark. Remember, 200hp/150lbs is right around the H22a's numbers, just something to think about...
Old Apr 16, 2002 | 10:23 AM
Maximus's Avatar
The prelude motor weighs more than b series motors. As the saying goes theres no replacement for displacement. If there was a test between a b18 and b20 both moded the same way the b20 will win.
[Modified by Maximus, 7:23 PM 4/16/2002]
nitewolf
Oct 4, 2007 09:51 AM
4doorluv
Dec 1, 2006 09:06 AM
jdm92teg
Apr 28, 2005 10:06 AM
todaspecsi
Mar 23, 2004 07:55 AM
