Integra front brake swap only on my CX hybrid...will it be good enough?
I'm thinking of just replacing my front brakes for now to Integra rotors/calipers. How much will they help out? I mean, compared to doing the full front/rear Integra brakes swap. Most of the braking done is from the front anyway.
-Todd
-Todd
Re: Integra front brake swap only on my CX hybrid...will it be good enough? (Todd C)
I did the front and the rears. Fronts should probably be good enough though.
-Todd
-Todd
Re: Integra front brake swap only on my CX hybrid...will it be good enough? (C5_ALLMOTOR)
i did the gsr front swap, but i kept the cx booster qnd cylinder, it works good, do i need to change them, i hear they are the same?
I did the front and rear gsr swap on my 97 cx but the brake balance is all messed up, too much braking from the front... Understeer is a bitch! is it the gsr master cylender or or booster or what that controlls frnt to rear balance??
Re: Integra front brake swap only on my CX hybrid...will it be good enough? (LShbVTEC)
Re: Integra front brake swap only on my CX hybrid...will it be good enough? (SuperDuperEG)
Thanks will do..
what master cylendar will match up with my hard lines??? I dont want to kink them trying to bend them?. and would junk yard stuff be ok or should I get it from honda??
Thanks will do..
Re: Integra front brake swap only on my CX hybrid...will it be good enough? (Katman)
According to local Honda dealership, all civic proportioining valves are the same... I guess i'll get the gsr one... is ther a MC that will bolt righ up?
Also, what Rotors and pads would you reccomend upgrading to?
[Modified by LShbVTEC, 11:02 PM 4/17/2002]
streethondar
01-13-2011 05:49 AM
98silverhatch
11
09-26-2002 05:14 AM
Yellow Dragon
04-16-2002 10:19 AM
