B18b swap parts list...am i missing anything??
I'm swapping a ODBII b18b into my 98 civic sedan, here is the list of the stuff I have, do I need anything else before I start this project???
Motor
Tranny
ECU
Axles
Shift Linkage
Throttle Cable
Mounts
A/C bracket
Upper and Lower Radiator Hoses (Do I even Need these)
Also 2 more things
1. I am replacing the water pump and the timing belt, should i also replace the oil pump? The motor will be boosted in the future and only has 40,000 miles on it.
2. I was told that since I have an ODBII dx nonvtec and I am putting an ODBII nonvtec motor in I can still use my dx wiring harness, is this true?
[Modified by sydag5, 9:25 PM 4/21/2002]
Motor
Tranny
ECU
Axles
Shift Linkage
Throttle Cable
Mounts
A/C bracket
Also 2 more things
