Need help, getting a ECT CEL ?? any suggestions?
Old Apr 23, 2002 | 07:21 AM
J_SpeC_EK's Avatar
Default Need help, getting a ECT CEL ?? any suggestions?
sup.. i'm gettin a ect CEL problem, and i have no idea which sensor that is,, and i think that's the reason it's makin my car idle at 1500.. can anyone point me to the sensor?? i'm running a 97 civic ex coupe with a 98 gsr motor.. i used a 97 ex harness, with a obd I gsr ecu, usin a jumper harness.. any help would be greatful thanx...
[Modified by AzN_J_SpeC, 8:22 AM 4/23/2002]
Old Apr 23, 2002 | 09:12 AM
memphiss13's Avatar
Default Re: Need help, getting a ECT CEL ?? any suggestions? (AzN_J_SpeC)
ECT is on the left side of the motor. its near the upper radiator hose.
Old Apr 23, 2002 | 11:09 AM
b19coupe's Avatar
The Engine Coolant Temperature sensor is on the right side of the cylinder head above the transmission. It has a two pin electrical connector going to it. The one pin sensor is for your temp. guage. Code #6, correct?
[Modified by b19coupe, 8:10 PM 4/23/2002]
Old Apr 23, 2002 | 09:04 PM
J_SpeC_EK's Avatar
Default Re: Need help, getting a ECT CEL ?? any suggestions? (b19coupe)
i found the problem,, i had the vtec and ect plugs swapped maybe that's y vtec wasn't engagin.. duh.. thanx for those who relpied..
Arakami
Jul 16, 2011 09:33 AM
sk8board{Pete}
Dec 14, 2010 11:08 AM
honda_jdm89
Mar 12, 2010 06:14 PM
skUnK2jdm
30
Feb 5, 2008 11:00 AM
ek-to-tha-max
Oct 7, 2005 02:50 PM
