4G hatch with 5G SI motor and 2G teg tranny...will it work?
New User
Will this setup work and bolt right in or will I have to get new axles? I am putting in a 5 gen Civic Si motor into a 4 gen Civic hatch. I know I can use the 4G tranny, but it only has 4 gears. If I bolt on a 2 gen Integra tranny however I get better gearing and 5 speeds, but was wondering if I have to modify the axles or use first gen Integra axles????? Any help would be appreciated.
New User
Re: 4G hatch with 5G SI motor and 2G teg tranny...will it work? (BlowOff)
no your an idiot a dohc tranny will not work on a sohc motor get a cable si sohc tranny
New User
Re: 4G hatch with 5G SI motor and 2G teg tranny...will it work? (HYBRID EG6)
Just wondering???? Can't you change the bell housing to make it work?
Stick with the 5 gen Si motor/4 gen Si tranny. Cool.
What axles?
[Modified by BlowOff, 2:42 PM 4/12/2002]
What axles?
Since the bell housing is also half of the transmission case, the answer is no. Try a B16 swap instead.
New User
Re: 4G hatch with 5G SI motor and 2G teg tranny...will it work? (meept)
OK so I am an idiot.
Here is what I got! 5 gen civic Si complete motor and cable si CRX tranny for $400
What axles do I use?
everyone starts somwhere dont assume they know as much as you all mighty one
KevronsEG
07-30-2003 06:30 AM
Blaze45
11-30-2002 08:00 AM
