taking advantage of LSD ?
Old Apr 13, 2002 | 07:52 AM
chameleon's Avatar
Default taking advantage of LSD ?
i think this is a topic not too much discussed!!
let's say we had to exact cars and 1 of them had LSD and the other didnt.. where would we really see the difference that we could actually tell if we didnt know which was the one with LSD..
especially with launching.. I guess cornering is a factor also..
where would we really see the advantages? and whats the best launch with LSD ..details.. thanks.
Old Apr 13, 2002 | 11:00 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: taking advantage of LSD ? (VTEC CX)
with a properly setup suspension, you'll never know which car is non LSD.
Use the front sway bar to preload the RF tire and run 1/2 psi lower in the RF slick.
just a stock SOHC VTEC on spray = 1.875 60 ft.
Old Apr 13, 2002 | 11:32 PM
Soku1kcivic's Avatar
Default Re: taking advantage of LSD ? (chameleon)
Yea i want to know too, i still dont no if my B16A hyrdo tranny has LSD iam to lazy to take off my axles and look to see if theres a bar or not well is there any way i can tell if i have LSD by just jacking up the car??????
THanks
Old Apr 13, 2002 | 11:35 PM
chameleon's Avatar
Default Re: taking advantage of LSD ? (Soku1kcivic)
THanks
yeah, jack up the car and spin one wheel, if they both spin together then you got LSD, if only 1 of them spins at a time then you are out of luck my friend.
Old Apr 13, 2002 | 11:54 PM
i put it in first gear and jack it up without starting the engine when i spin the wheel one spins a direction and the second wheel spin the opposite direction ?? and when i start the car and rev it in first gear both wheel spin iam still wondering if i have LSD ???
Old Apr 14, 2002 | 04:20 AM
chameleon's Avatar
both in the same direction, thats LSD, anything else and im not sure
Old Apr 14, 2002 | 02:38 PM
Max_ED9's Avatar
it should say on the tranny near the block... LSD
Old Apr 14, 2002 | 05:11 PM
like when i punch it in first gear and the car is on jack stand both wheel spin the same direction really fast, but if the car has not been started and i put it in first the spin opposite direction can any help i still want to know if i have LSD??
Thanks
1sikhatch
Aug 11, 2010 09:34 PM
RanCRX
Aug 4, 2008 11:26 AM
b16a3delsol
May 14, 2007 06:36 AM
JDMbull
Jul 10, 2006 07:09 PM
d mafia
Jan 18, 2002 09:52 PM
