Hitin the REF with this setup....will it pass?
Old Apr 28, 2003 | 10:09 PM
Mentat Ghola's Avatar
Default Hitin the REF with this setup....will it pass?
The car is a 89 civic LX. The motor is a 99 USDM motor. Everything is hooked up right, but it has been converted to OBDI, i was wandering if that will be a problem on the visual. I know it wil pass the sniffer. thanx
Old Apr 28, 2003 | 10:10 PM
Default Re: Hitin the REF with this setup....will it pass? (The B Man)
What kind of motor you ask? hehe. GSR, my bad
Old Apr 29, 2003 | 06:32 AM
ATS*VEEE's Avatar
I believe you need to hook up everything to OBDII.
Old Apr 29, 2003 | 12:15 PM
Colin's Avatar
Default Re: Hitin the REF with this setup....will it pass? (richierich)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richierich &raquo;</TD></TR><TR><TD CLASS="quote">I believe you need to hook up everything to OBDII.</TD></TR></TABLE>
you are correct. However if you swap over a couple parts you can tell the ref that the motor is a 94-95 gsr motor....that way you can just run obd1. I'm not familiar w/ the exact parts that need to be changed though. However there is an article about it over at hybrid-perf: http://hybrid2.honda-perf.org/tech/refstory.html
Old Apr 29, 2003 | 01:08 PM
Newman's Avatar
New User
Default Re: Hitin the REF with this setup....will it pass? (91IntegGS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91IntegGS &raquo;</TD></TR><TR><TD CLASS="quote">
you are correct. However if you swap over a couple parts you can tell the ref that the motor is a 94-95 gsr motor....that way you can just run obd1. I'm not familiar w/ the exact parts that need to be changed though. However there is an article about it over at hybrid-perf: http://hybrid2.honda-perf.org/tech/refstory.html</TD></TR></TABLE>
LOL... that's MY write-up from my CRX way back when Yeah, the smog ref goes off of the motor, so if he verifies with the VIN plate (if on there) or block stamp, that it's a 99 motor, then there's no way he'll pass you unless it's completely setup as OBD-2. You can try to make your motor look like an OBD-1 motor, and setup/hookup everything to OBD-1 standards under your hood and hope that the ref doesn't catch it, but it'll all depend on the ref himself and if he says something or not.
Trouble
Mar 16, 2008 11:09 PM
ej8hatch408
22
May 27, 2006 07:04 PM
atmosphere
10
May 14, 2006 12:05 PM
95civickid
Nov 30, 2004 09:03 PM
jimmhatch
Feb 10, 2004 10:41 AM
