wiring help h22 in 91 accord (searched w/o answer)
its a 91 accord stick that's getting a h22. I knowits obd1 but i cant find anything that shows which wire goes where for the ecu. Any help would be appreciated or if more info is needd then say so.
Re: wiring help h22 in 91 accord (polycrx)
can anyone help me, or at least point me towards a thread that has my answer, cause in mot the first one to ask
On the 90-93 Accord, everything will plug right in.... no extra wiring needed except for VTEC if your car doesn't already have it. PM/email me if you need an ECU pinout guide.
Re: wiring help h22 in 91 accord (Newman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman »</TD></TR><TR><TD CLASS="quote">On the 90-93 Accord, everything will plug right in.... no extra wiring needed except for VTEC if your car doesn't already have it. PM/email me if you need an ECU pinout guide.</TD></TR></TABLE>
thanks for the help, I couldnt find anything like this and it was driving me nuts
there is no vtec in a fourth gen accord so you must wire the vtec pressure switch and solenoid, also you have to wire for the knock sensor.
