Shift Linkage, and Axle In EK Question
Old Apr 29, 2003 | 03:21 AM
SpiritUnreal's Avatar
Default Shift Linkage, and Axle In EK Question
Sorry for the newb-like post but I've been searching around for a few days in my spare time and haven't found the answer to what i'm looking for.
For a B16A2 in a 97 EX
There's about a 500 dollar difference in a complete swap from motor tranny and ecu.
500 dollars is alot for just a shift linkage, axles, half shaft, and motor mounts.
so can't I just use my stock ex motor mounts for the swap, I know i'll need a rear mount.
Will my axles and half shaft work?
And what about the shift linkage?
Thanks
Old Apr 30, 2003 | 12:19 PM
Default Re: Shift Linkage, and Axle In EK Question (SpiritUnreal)
bump
Old Apr 30, 2003 | 03:31 PM
vtec69's Avatar
to tell you the truth id go with the whole swap.
Its a pain in the *** trying to find all the mounts u need
Ur axles will not work u need axles from a 00 civic si and im almost certain that that car doesnt have a half shaft so you cant use the stock one
and you will need a shift linkaghe form a 00 si or a 94 del sol
-Brian
Old Apr 30, 2003 | 10:51 PM
sivik2nr's Avatar
Yeah, it will go ALOT easier. Then you'll have everything from the same car. You'll need the B16 rear and drivers side mounts too.
Old May 1, 2003 | 08:27 AM
ITRacer121's Avatar
Default Re: (sivik2nr)
go with the full swap! I got screwed on my swap and it didnt come with stuff you are mentioning, so I went to HONDA yesterday and they want like $900 for all of it.
THANK GOD for Junk Yards! (found majority of it for $200 at a junk yard but still a pain to locate all of it!)
Old May 1, 2003 | 11:59 AM
Trey's Avatar
25 Year Member
Default Re: (ITRacer121)
EK swap guide in my sig below.....
Old May 1, 2003 | 09:54 PM
Default Re: (Trey)
Thanks guys
crx4ever
Jun 12, 2006 09:45 PM
nk2k2
Feb 9, 2006 04:27 PM
noboostedEGo
Oct 20, 2005 12:39 PM
BlackNoise
Mar 11, 2004 06:53 PM
