H22 in a 90-93 integra DA possible?
Can this be done with out doing alot of work. I know there would prob be some welding but with out alot of work can it be done?
Re: H22 in a 90-93 integra DA possible? (VTec Tuning)
I'm not sure if place racing makes a mount kit for it. I would search for their number and give them a call.
good luck.
good luck.
Re: H22 in a 90-93 integra DA possible? (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">Ahh, you'd have to find a mount kit. ALOT of work to get it mounted.</TD></TR></TABLE>
I don't think any mount company makes a kit for the DA for a H22 swap. I've seen it done, but the owner welded custom mounts in and had to cut away some of the chassis frame rail and pound in the firewall quite a bit. The DA chassis is small, similar to an EF so think about how much work you need to do to get a H22 into an EF and there you go.
Re: H22 in a 90-93 integra DA possible? (Newman)
As previously posted, it's not at all easy.
http://www.g2ic.com/forums/sho...38801
That thread lists the basic problems that this guy had to solve to get an H22 in there. You've gotta have the guts and knowledge to start changing things around in the chassis.
NA-Cutie
01-31-2005 05:14 PM
