99-00 swap guru's need help fast!!!!
Old 04-24-2003, 07:57 AM
HybridHatchC1's Avatar
Default 99-00 swap guru's need help fast!!!!
my neighbor is in the middle of a swap hes got a 2000 ex and hes swaping in a 98 gsr, which wiring harness should he use, also if somone has a diagram that would be much appreciated, thanks Tim
Old 04-24-2003, 09:52 AM
Default Re: 99-00 swap guru's need help fast!!!! (HybridHatchC1)
anyone help!! please!!!!
Old 04-24-2003, 12:17 PM
Trey's Avatar
Use the Civic Harness since it's one piece and the teg is two piece. check the link in my sig for the other parts he'll need.....
Old 04-24-2003, 07:01 PM
nyEKhatch's Avatar
Default Re: 99-00 swap guru's need help fast!!!! (Trey)
Hey, use Trey's swap guide it is the sh*t. Oh and Trey I
just realized why my swap won't idle and I'm getting a
engine code for IAC, I didn't move the pin for it!!!
From a 14 to a12, I am a dumb as*!!
Just want to say thanx for the guide, helped alot.
Old 04-24-2003, 09:08 PM
Fowler.'s Avatar
Default Re: 99-00 swap guru's need help fast!!!! (nyEKhatch)
The easiest harness to use would be t he 99-00 Si harness. You'd only have to add the wires for the secondary buttlerflies. Everything else would be kosher.
Good luck.
04-09-2018 05:14 PM
SanFranGunners
04-16-2008 02:47 AM
sant0r0
08-16-2005 11:43 AM
JDM Approved
11-10-2004 03:21 PM
Quick Reply: 99-00 swap guru's need help fast!!!!
