secondaries manifold on GSR
Can some one please help me here. I am all done with my swap; 97 GSR in A 95 RS but the butterflies won't kick in. i have the red wire underneath the car hooked up to the A17 on the ECU and the black wire to the ground is there anything I am doing wrong?
Re: secondaries manifold on GSR (hondaitegra)
look for a pink/blue wire that is on the driver's side harness, if you find that, a wire goes from there to A17, I am pretty sure. I have never done it by running wires from the unit and not the harness. I know that the pink/blue should work and not even need a ground, but someone else might want to edit this
Re: secondaries manifold on GSR (BCRUZ)
Yes I am running an OBD1 ECU. and are you sure I have to swich A17 to A20 and A20 to A17. By the way I don't have to give it a 12V power do I?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaitegra »</TD></TR><TR><TD CLASS="quote">Yes I am running an OBD1 ECU. and are you sure I have to swich A17 to A20 and A20 to A17. By the way I don't have to give it a 12V power do I?</TD></TR></TABLE>
yes I am sure. don't ask for help if you aren't gonna listen.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BCRUZ »</TD></TR><TR><TD CLASS="quote">
yes I am sure. don't ask for help if you aren't gonna listen.</TD></TR></TABLE>
BCRUZ saves them again
Re: secondaries manifold on GSR (bigblockEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigblockEG »</TD></TR><TR><TD CLASS="quote">look for a pink/blue wire that is on the driver's side harness, if you find that, a wire goes from there to A17, I am pretty sure. I have never done it by running wires from the unit and not the harness. I know that the pink/blue should work and not even need a ground, but someone else might want to edit this</TD></TR></TABLE>
This is what I did. Ran the one wire from the shock tower back to A17.
Re: (sivik2nr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sivik2nr »</TD></TR><TR><TD CLASS="quote">How do you know if your secondaries are opening or not? Would it trigger a CEL if it's not working?</TD></TR></TABLE>
I'm not sure about the cel issue but by looking at the IAB aka secondaires(under the intake manifold, when you rev the engine to about 5500 rpm you should see the IAB rotate meaning it works or not rotating it's not working hence it will tell you if it's working or not.
Yeah... he should just listen to the first piece of advice given, eh ? Everyone on the net is right...lol
X2
X2
Re: secondaries manifold on GSR (X2BOARD)
I did all that; and then all of the sudden I had a problem with my check engine light. It came on and the car doesn't rev past 3500. So Some one told me it's the distributer since it's OBD2 and my ECU is OBD1
any suggestions please
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaitegra »</TD></TR><TR><TD CLASS="quote">Can some one please help me here. I am all done with my swap; 97 GSR in A 95 RS but the butterflies won't kick in. i have the red wire underneath the car hooked up to the A17 on the ECU and the black wire to the ground is there anything I am doing wrong?
I just swapped a JDM B18C into my 2000 Civic Si... You need to run one wire directly to the P72 ecu... pin A17. I can't remember the color right now. The other wire needs a 12v connection.
Re: (pills_PMD)
what is a limp mode and is it fixable?
what I did was I unpluged the injectors and I tried starting the car. I didnt remember that they were still disconected.
Re: (sivik2nr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sivik2nr »</TD></TR><TR><TD CLASS="quote">Would it trigger a CEL if it's not working?</TD></TR></TABLE>
no it won't
no it won't
Re: (hybrider)
I ran a wire directly to the ecu from the secondaries harness and it still wont work. Just out of boredom i hooked the wire to the vtec wire and ran it for a while, it worked great until i got a cel for vtec sel. voltage owell, i sould like to fix this soon.
Re: (likaciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by likaciv »</TD></TR><TR><TD CLASS="quote">I ran a wire directly to the ecu from the secondaries harness and it still wont work. Just out of boredom i hooked the wire to the vtec wire and ran it for a while, it worked great until i got a cel for vtec sel. voltage owell, i sould like to fix this soon.</TD></TR></TABLE>
One wire goes to the ecu, and the other goes to a 12 volt connection. When you connect it to the 12 volt connection it will remain open. Personally I don't know if this is good or bad.
All that is just too complicated. Just take out the center butterfly piece, and buy shorter bolts and it will eliminate your entire problem. Mine works just fine. Just my .02
Re: secondaries manifold on GSR (Imadreamer1226)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Imadreamer1226 »</TD></TR><TR><TD CLASS="quote">All that is just too complicated. Just take out the center butterfly piece, and buy shorter bolts and it will eliminate your entire problem. Mine works just fine. Just my .02</TD></TR></TABLE>
So basically you made your car slower.... great advice
X2
X2
So I made my car slower. Do explain yourself. Not being sarcastic at all, but I didnt think it would at all hurt the performance. Let me know.
EG6 SiR
02-17-2005 09:00 PM
B18Cej1
18
03-02-2004 03:33 PM
