hooking up vacum lines for hf ctx to skunk2 intake manifold on b18c
hooking up vacum lines for hf crx to skunk2 intake manifold on b18c
I need help identifying vacum lines. I bought a Haynes manual and it doesnt have the vacum diagram that i need so im looking for everyones help. i have 4 vacum hoses coming from my car and i only need two that go to the manifold. one is for the EVAP and one is for the fuel pressure regulator. and i assume i just plug the other 2. i would appreciate you help because i plan on doing the swap this weekend. The 4 vacum lines im talking about come from the firewall with the charcoal canister and map sensor are located. thanks everone.
Modified by legutki at 9:50 PM 4/23/2003
Modified by legutki at 9:51 PM 4/23/2003
Re: hooking up vacum lines for hf crx to skunk2 intake manifold on b18c (legutki)
from your cannister, the very top nipple, it should say 'purge' on it...that goes to the EVAP sensor
the other one (should be right under the one I was just talking about) from the cannister should go somewhere right above the throttle body.
I don't know about the other two lines you're talking about..most of the cannisters I've seen usually on have 3 lines, and one of those just goes back down to it's own thing.
Re: hooking up vacum lines for hf crx to skunk2 intake manifold on b18c (hot_EG)
The other 2 are not on the canister but on the firewall next to the map sensor combo there a black box that covers this and they pug into the stock im. any suggestions on what to tee and what to plug anybody
hmmm...I'm not exactly sure what you're trying to explain
Can you get a picture up?
