h22 swap idle problems?
Old Apr 28, 2003 | 08:22 PM
ki11a8ee's Avatar
Default h22 swap idle problems?
I just finished swapping an H22 into an 99dx, and everything is fine, except when I'm driving, the rpm does not come down, until I come to a complete stop. When I'm coming to a stop, and I put the car in neutral, it will stay at ~3000 rpm until I come to a complete stop.
Old Apr 28, 2003 | 08:25 PM
yaya's Avatar
Default Re: h22 swap idle problems? (ki11a8ee)
no codes?
check vacuum lines?
man i really dont know
Old Apr 28, 2003 | 08:39 PM
ki11a8ee's Avatar
Default Re: h22 swap idle problems? (yayaRl337)
no codes vaccum lines are fine
Old Apr 28, 2003 | 08:56 PM
poison's Avatar
you check the things I was tellin you about earlier?
make sure the fast idle screw is all the way in..
there is a plate on the back lower part of the throttle body and a screw inside..
burp the coolant system. lower the idle screw (screw it into the TB), make sure there is no vacuum leaks.
make sure all hoses are sealed and all nipples on the intake manifold are closed or going somewhere.
also take off your IACV and wash it with brake cleaner or carb cleaner.
HTH.
Old Apr 29, 2003 | 04:32 AM
Civic Rs's Avatar
New User
Default Re: h22 swap idle problems? (poison)
I had this problem... Just put your TPS at the right voltage and you will be fine
Old Apr 29, 2003 | 06:45 AM
Jason kiDD's Avatar
That just sounds like your throttle cable is sticking. What bracket and line are you using for it. It just needs to be adjusted..
Old Apr 29, 2003 | 07:21 AM
Jonathan_ED3's Avatar
Default Re: (Jason kiDD)
Yeah, mine does almost the same thing because my throttle cable is slightly sticking.
I'm going to have to fabricate a new throttle cable bracket to hold my ultra long cable properly.
Turbokid13
Feb 3, 2005 08:56 PM
FastSS
Aug 31, 2004 09:20 AM
Speedra500
Aug 3, 2004 07:13 AM
killa_lude
Jul 17, 2004 08:39 AM
