Del sol shift linkage on 93 CX?
Will the VTEC Del Sol's shift linkage be able to work with the GSR's shifter stabilizer going into the 93 Civic CX?
Need to know ASAP.
Need to know ASAP.
Re: Del sol shift linkage on 93 CX? (P1mpSlap)
no. the delsol shift linkage is a bit longer and bends up and wont work with the stabilizer bar. any b-series shift linkage and stabilizer bar from a DC integra will work.
Re: (P1mpSlap)
if you put a del sol b-series shift linkage along side a b-series integra, they are different. it will not work. the del sol has a bend that helps the shifter reach the cabin inside the car. in a delsol, the shifter is closer to the steering wheel than a teg or a civic. i own a del sol. they are both different. if you want to cut/weld/straighten out the del sol linkage, thats another story.
Delsol shiftlinkage (B series and D series) is different shape and length as Denmatic said,it doesn't work on a civic,you need linkage from a teg or civic based B series.
redline870
03-23-2011 09:30 AM
gsrpedro
08-20-2008 11:23 PM
