P13 Code 14
Old Apr 26, 2003 | 11:13 AM
junglerunna's Avatar
Default P13 Code 14
Im throwing Code 14 Idle Air Control Valve. Im using P13 ecu. I converted my car to OBD1, and im using the dx engine harness. So on the engine harness for that sensor theres an orange, yellow/black, and black/blue wires. I wired up yellow/black to yellow/black, and black/blue to black/blue. And I did not connect the orange wire. Then I tried to hook the black/blue wire to the orange wire and that still didnt work. So Im still throwing code 14. What should I do.
Old Apr 26, 2003 | 12:43 PM
Default Re: P13 Code 14 (junglerunna02)
Old Apr 26, 2003 | 02:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junglerunna02 &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Old Apr 27, 2003 | 06:34 AM
ttt
Old Apr 27, 2003 | 11:02 AM
Somebody gotta know whats up
Old Apr 27, 2003 | 11:36 AM
Jonathan_ED3's Avatar
You probably need to get a two wire IACV like the H22 should have stock, and make sure black/blue goes to A9.
Anyway you can try that out?
Old Apr 27, 2003 | 11:45 AM
Default Re: P13 Code 14 (hot_EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hot_EG &raquo;</TD></TR><TR><TD CLASS="quote">You probably need to get a two wire IACV like the H22 should have stock, and make sure black/blue goes to A9.
Anyway you can try that out? </TD></TR></TABLE>
I am using the 2 wire IACV but my harness just happened to have 3 wires because it was obd2.
Old Apr 27, 2003 | 12:56 PM
well then disregard the orange wire all together.
Make sure black/blue goes to A9. Yellow/black should already be going to a power from the junction connector, if it's not, try wiring it to A25.
If both of those are right, I'd say you've got a bad sensor.
Maybe you're in the same boat as me....You know the wiring is right, you know the sensor is good, and it's still throwing the stupid code
Old Apr 27, 2003 | 04:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hot_EG &raquo;</TD></TR><TR><TD CLASS="quote">well then disregard the orange wire all together.
Maybe you're in the same boat as me....You know the wiring is right, you know the sensor is good, and it's still throwing the stupid code </TD></TR></TABLE>
Well I never ran the IACV anywhere i just extended the wires so the sensor on the harness would connect to the sensor on the motor if you know what I mean. So I did not run anything back to the ecu for the IACV. So what you are suggesting is that I run the black/blue wire to A9.
Old Apr 27, 2003 | 05:05 PM
poison's Avatar
Jon has it all down
I would suggest making sure it's to the A9 pinout and making sure there is continuity thru the Yel/Black wire.
Also, grab a multimeter and see if voltage is going thru A9 as well.
Old Apr 28, 2003 | 12:06 AM
Default Re: P13 Code 14 (poison)
Alright Ill try that
Old Apr 28, 2003 | 08:20 AM
poison's Avatar
Keep us updated
Old Apr 28, 2003 | 09:27 AM
Yeah I guess I must have skipped over that part when reading the how to swap an h22 into an ek instructions.
96romaEK
Apr 18, 2010 12:22 AM
trooper0641
Feb 18, 2008 02:00 PM
EK22snatch
Sep 6, 2004 11:51 PM
dingusjt
10
Nov 16, 2003 05:18 PM
