Shuddering when accelerating??
Old Apr 27, 2003 | 06:30 PM
Jonathan_ED3's Avatar
Default Shuddering when accelerating??
I can't tell what's causing it...
I don't know if it's just the stiff mounts pushing a little vibration through the car when I get on the gas or what.
People running Hasports....do you have slight vibrations when accelerating?
Old Apr 27, 2003 | 10:53 PM
H22ek4's Avatar
Default Re: Shuddering when accelerating?? (hot_EG)
you get use to it, especially when you shift into gear and the dash and door panels would shake and your neck would jerk every time you shift gear.
Old Apr 28, 2003 | 04:32 AM
EFb18b's Avatar
Default Re: Shuddering when accelerating?? (H22ek4)
Might wanna check the clutch and flywheel as well just to be sure. If the flywheel gets a hot spot on it, it can create a vibration on take off.
Old Apr 28, 2003 | 09:15 AM
Default Re: Shuddering when accelerating?? (Redlineracer)
Thanks guys
Old Apr 28, 2003 | 09:26 AM
NXSpoon's Avatar
Does the shuddering happen all the time??? Or just when the motor is cold, or hot?? My B16 in my Civic does it a little when the car is first driven in the morning. It has a Toda flywheel and Exedy clutch. And engine mounts are all reinforced with inserts, plus a HASport driver side mount. But after warmup, it never happens.
Old Apr 28, 2003 | 10:45 AM
Default Re: Shuddering when accelerating?? (NXSpoon)
yeah it's all the time.
I'm pretty sure it's just the stiff mounts.
Like if I'm in gear, and stomp on it....it pushes a lil vibration through the car.
globy123
56
Sep 16, 2018 05:53 AM
Cashmoney061596
Feb 7, 2014 12:28 PM
aemintgsr
16
Oct 21, 2013 02:20 AM
itslogz
Mar 19, 2008 02:24 PM
1.8
23
Jan 16, 2005 02:15 PM
